what causes f/i setups to overheat?
Old 07-16-2011, 08:08 PM
  #31
what a rush!
moregrip's Avatar
excellent info zippy, thanks!!!
Old 07-18-2011, 01:32 PM
  #32
chpspecial's Avatar
Sorry to somewhat steal your thread moregrip, but hopefully we can get a solution together as i'm havin a similar situation as you...
Originally Posted by zippy
Honestly the most common problem I've ran into and fixed is a tuning issue. Many are tuned with too little timing in the non-boost/low boost range and this will easily cause overheating conditions. Even with the stock stat it should be fine. I'd run a 160 in your setup for various reasons, but not to keep it from overheating. Seriously, check the timing you run at cruise and zero to very low boost situations. Also make sure that when you are in boost you are going into p.e., because if you don't this will also create a ton of heat in the cylinders. Heat in the cylinders will be transmitted to the cooling system.
Something else to consider would be change the heat exchanger and get it out of the way of the radiator. I've also re-located them for this reason. There are many other options for this.
On a side note, turning on the fans at highway speed will slow down the air coming through the radiator, not speed it up. Only an engine driven style fan can get away with it since it speeds up as you speed up. Have you upgraded your fans to both 7 blade setup for low speed help?
Zippy, in my truck at partial throttle and the 0vac/boost region I am seeing 29-32* of timming is that too low or too high. PE comes in at 105kpa and slowly ramps in with boost. As boost goes up, PE goes down. at 5psi I see full PE of 11.22 AFR. Between 0 and 5 psi of boost, PE goes from 13.5 and ramps down to 11.22 AFR.Once boost comes in steady and PE is active, my timing ramps down from said 29-30* down to 22* @5psi and 18*@10PSI and 15-16* @15 pounds. What else in the tune could possibly be causing my truck to see increased coolent temps. Lastly I am going to replace the exhaust housing to a larger one to see if that help out also. TIA
Old 07-18-2011, 06:51 PM
  #33
what a rush!
moregrip's Avatar
Dude, no one is stealing...all good and pertinent info!!
Old 07-18-2011, 07:13 PM
  #34
I have a gauge for that
Atomic's Avatar
Thats a pretty good amount of timing for that amount of boost...are you running meth or e85?
Old 07-18-2011, 09:49 PM
  #35
chpspecial's Avatar
No, just cali 91 octane and lots of VE tuning.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
Gadgetized
10-22-2015 09:06 AM
GMCtrk
18
10-06-2015 03:48 PM
blackedoutchevy22
10-01-2015 08:07 PM
StrokeTheLS
09-29-2015 08:33 PM
Quick Reply: what causes f/i setups to overheat?
