What do yall know about a 160* Tstat and FI vs Stock Tstat??
Old 09-10-2007, 09:11 PM
nonnieselman's Avatar
Originally Posted by ranwalk
Get it Nonnie, I have been running a 160 stat for 3 years now. Heater works just fine.
Ah,, I forgot about you..
WHere you get yours from?
Old 09-10-2007, 09:20 PM
WorkTruc's Avatar
It also helps tranny temps stay about 20 degrees cooler
Old 09-10-2007, 09:22 PM
Thats goin to be a Plus!!
i tend to drive my truck kindof hard until the trans temps get up to 200.. then its babying it till they drop down.
Old 09-11-2007, 06:13 AM
FastCrewCab4x4's Avatar
With a stock tune, or even a handheld the 160 hurts milage (it did mine) I guess due to the fact it stays open loop longer or stays open loop full time. If you can tune for it there shouldn't be a problem.
Old 09-11-2007, 07:24 AM
krambo's Avatar
Originally Posted by XLR8NSS
I don't think there really is any cons to it. You may have to turn your heat up a notch in the winter but, that is about it.
The guys at W2W have done testing that shows how the #7 cylinder problems can be related to high engine temps since it gets less cooling than other cylinders. So anything you can do to help it out is good. Kinda like having a good safe tune to help it out too.(Had to throw that in there for the #7 bad tune debaters )
Old 09-11-2007, 09:10 AM
Moderately Differentiated
dewmanshu's Avatar
from all the reading i have done, it does hurt mileage. I couldn't tell ya though, I have so much other **** done to mine that hurts mileage too...who knows in my application. I'd guess different things that are just a combination of the lower stat causes poor mpg. Like more spark will make you want to get into it more...lol...so bye bye mpg.
Keep in mind, it's not gonna run at 160*, it will still run at what ever is operating for ya. It will just stay open more or all the time. In the 90* plus weather I hover around 189 to 198 temps with the 160stat. I guess that means mine is always open huh?
nonnie you are in SD but are you open loop? If you are closed loop what is your closed loop enable temp?
Old 09-11-2007, 07:43 PM
BlewSilverado's Avatar
I lost right at 1 mpg and it was tuned for a 160 stat. I check my mileage every time I fill up and it was consistently 1 mpg less.I do feel the gains outway the mpg loss by far. I also gained about 1 mpg back with efans.
Old 09-11-2007, 08:22 PM
EFI Live baby!!!!!!
Old 09-11-2007, 08:24 PM
Yea i figured that... but ill prob go ahead and get a 34" Radiator soon.. i plan to tow alot with my truck so ill take whatever i can get...
HUH? haha let me look...
Im still learning this thing called "Tuning"
Just got through lookin at my tune...
Im in Open Loop cause my Closed Loop Enable Temp is set at 252*F.
Old 09-11-2007, 08:29 PM
School me on OL and CL....... this has always been confusing to me..
Quick Reply: What do yall know about a 160* Tstat and FI vs Stock Tstat??
