What do you think about this cam??
212-220 557/564 on a 118 lsa . This is going in a 99 rcsb 4.8 stock heads,patriot golds. Mpt 70/.96ar I plan on running 10-12lb no meth, 4l80e w hd2, converter is undecided. Looking for that good old 500rwhp like all the other cool kids.
Once in boost turbo cams are not vary picky, can't say I've ever seen much of a power gain from one cam to the other, just keep in mind you want to match the cams power curve with the turbo. If you have a 70 mm turbo with a 64 ex wheel you will spool around 3500 and tap out by 6500 in a 4.8 so find a cam that will pull there if it were a na 4.8. Seen way to many people run230s cams with tiny ex wheel.
