What do you think of this turbo?
Old 08-18-2011, 07:35 PM
black04's Avatar
I would run it with the flat tops just keep the boost low. Should be a pretty good setup with lots of torque on the street.
kbracing96's Avatar
Buy it and run it! If you want to go bigger, you can always sell it and buy a new turbo. Keep the flat tops, higher compression is not a bad thing with mild turbo setups. My next motor will be at least 10:1. It will give you more torque out of boost. LS2's are around 11:1 stock and they love boost!
This will be a BIG torque setup. A fun to drive 2000-5800rpm torque monster!
Old 08-18-2011, 07:45 PM
kode-x-kustoms's Avatar
I think I'm gonna buy it!
I would run it with the flat tops, the only thing is 11.5:1 is the lowest I could get with a really thick head gasket and stage 2 6.0 WCCH's, I would have ran some where around 11.7-12:1 in the end, so I don't really feel like anything good could come of that.
How much boost could I safely run with around 9.5-10:1?
Thanks
Kody
Old 08-18-2011, 08:34 PM
Blak92's Avatar
I would go with a bigger turbine wheel, I just sold off a TC76 turbo, turbonetics F1-68 wheel, 68mm exducer. I ended up with a 3:1 pressure ratio on a SBM 408ci stroker at 10psi (30psi in the exhaust). Granted this is with a rear mount setup, but I am moving up to a S400SX3-76 with the 83/74mm turbine wheel per Reed at Work Turbo. Im not an expert by any means, just throwing out my experience with the same size motor.
Originally Posted by kode-x-kustoms
Hey guys,
After getting my 408 stroker kit in I kinda got urge to build a turbo motor. Well I looked around and just did want to spend that kinda cash. Long story short I got a better paying job and have got a friend that is going to make me a deal a brand new precision turbo. I just want to make sure it will be a good turbo for my 408.
He says it is a 76mm compressor and a 68mm turbine, and is a ball bearing on a .86 a/r. Would this turbo be too small on a 408?
Thanks
Kody
Old 08-19-2011, 04:34 AM
TURBHOE's Avatar
i'd at least get a bigger housing for it. .96 A/R at least.
Old 08-19-2011, 05:57 AM
Blak92's Avatar
Glad you said something, that was with a 1.15 AR housing too, the biggest they offer for that turbo (at the time at least, last year).
Old 08-19-2011, 03:44 PM
TURBHOE's Avatar
I was refering to the OP. Was your 1.15 a divided tang? I was told by forced inductions to take off like 10% of the a/r on a divided tang and that's it's comparison to an open tang. Basically a divided 1.15 is just a touch better than a .96 open. I have a tc78 myself and I love it but I have a 5.3 not a big *** 408. But it makes stupid power. After my last set of tweaks I think I'm ready for high 11's.
Old 08-19-2011, 10:25 PM
Well it is all mine!! When he said it is new he was not joking it still has all the stickers on it. But I might still have a friend of my dads who is a turbo guru just go through it.
I did call turbonetics and asked if they had a higher a/r housing and he said they have a .92 I but he also said he thinks the .86 would be a decent set up but there is the possiblity of it choking out.
I will get pictures tomorrow.
Thanks
Kody
Old 08-19-2011, 11:06 PM
M&M Turbochargers's Avatar
sounds like a good buy ,, lett er buck chuck
Old 08-24-2011, 06:01 AM
Hey guys,
I am a bit curious... I am going to buy the kbracing hot pipe kit, and I think that might be my next buy. Could the stock 6.0 valve springs handle a enough boost to have a little fun till I can finish ordering parts for the 408?
Thanks
Kody
Quick Reply: What do you think of this turbo?
