what headers for a 370/f1-r setup
11 Second Truck Club
guys what headers and wich one will fit my truck? i want to run the kooks headers. but wich ones should i go with 1 7/8x2 or 1 3/4 and for what application do i order them? This are going in a 370 w/ etp 245 heads, vic jr intake, f1-r procharger going to run 15psi to 20 psi.
No idea about the headers, but your truck is going to be an ANIMAL.
Actually I think Quik had some Kooks headers that were 1 7/8 stepped to 2. Pretty sure on a 2wd the Kooks f body headers will fit.
Saw a header test a couple of years or so back, maybe Car Craft or Hot Rod. I would definitely do 1 7/8 with your setup.
i would go 1 7/8 kooks or 1 7/8 stepped 2 inch if you can afford them Flaco is running them in his. you need the big diameter on larger motors. TSP just did a test. 1 3/4 vs 1 7/8 and up till 4800 rpms they were the same. from 4800+ the 1 7/8 gained nicely on a stock motor. you can find this test in the dyno section on tech
Ken in AZ
09-17-2015 07:08 AM
