what headgaskets for turbo lq4
IF you are planning to run high $$$ heads down the road, build a forged motor and/or run on the ragged edge with timing/fuel, then ARP's would be a prudent purchase.
That said, I bought ARP's studs for my last build so I can have the option of turning up the boost down the road. What year is your donor block? 1999-early 2004 blocks require the ARP #234-4316 (long) stud kit. Late 2004-2006blocks require the ARP# 234-4317 (short) stud kit.
Rick
At 8lbs, ARP head studs are an unnecessary luxury. People run 10-12lbs all day long on OEM head bolts without a hitch. At about $60 per set, you'll have to change them over 4 times before you break even on what ARP's cost.
Rick
Rick
yeah i put OEM bolts in mine 10lbs....just because at this point i am not looking at having a race motor that I would need to drop alot more money $$$ than i already have. 10lbs DD OEM will work with the OEM MLS gasket.
Unless you have a hard on for ARP you dont need them.
x2 for rick
haha thanks guys.. this motor i dont want to push anywhere over 8lbs.. why?? because ima be on the sand .. prerunning all the time.. thats all i need as far as boost on this block.
this block is from a 2000-02 lq4
i guess i will be buying some stock head bolts for now...
dealer?
lxcoupe
08-26-2015 07:24 PM
