What muffler/resonator that maintains turbine whistle?
Old 12-08-2012, 02:51 AM
Jetn3's Avatar
Default What muffler/resonator that maintains turbine whistle?
What muffler or resonators are you turbo guys using that maintains TURBINE whistle but still quiets the exhaust?
Turbo Diesel guys have been using FTE resonators (no cats & no mufflers) that quiets down the exhaust but still maintains turbine whistle. It's a 4" inlet/outlet, 5"x17" or x30" case with a 2" straight pipe inside and auger blades around the 2" pipe that cancels sound. Also claims NO flow loss. Any thoughts if this resonator would work the same on a turbo v8 gas motor(5.3)?
How about guys that use 4" diesel mufflers like mbrp, is turbine whistle audible?
Old 12-08-2012, 02:01 PM
Alpinestar's Avatar
Just don't get a tiny muffler that is stupid loud.
Old 12-08-2012, 03:06 PM
Jetn3's Avatar
What muffler do you use? Can you hear turbine whistle through your muffler?
Old 12-08-2012, 04:22 PM
Alpinestar's Avatar
The whistle sound comes from the turbo itself (under the hood for front mounts), not so much "through the exhaust". My point earlier was, a loud muffler can overwhelm the sound that the turbo makes. I've ran a few borlas and now I'm trying out a magnaflow.
Old 12-08-2012, 05:20 PM
Registered User
turbo-ls7's Avatar
Wasting Ur money whith magnaflow man it sounds like a damn 6 banger rice burner for real but when u put Ur foot in it sounds some what good I'm going back to corsa sport
Old 12-08-2012, 06:31 PM
Alpinestar's Avatar
My truck sounds nothing like a ricer or even a v6 at that.... Maybe all the ricers in your area have v8 swaps?
Old 12-08-2012, 08:50 PM
Registered User
turbo-ls7's Avatar
Well my truck ant no ricer for sure I had a built 416 at idle sounded mean but I just think it sounded like a 6 banger around 25 to 40 for some reson I didn't like that at all
Old 12-08-2012, 10:10 PM
Choda's Avatar
I have full 3 inch into a 40 series flow master. Not cats or res.
Sounds great at idle, cruise and wot
Old 12-08-2012, 11:51 PM
Three6GMC's Avatar
a 416 that sounded like a v6?
Anyways anything straight through should keep that spool sound your looking for but still depends on the turbo. The reason the diesel trucks, specifically the Fords really have that distinct spool sound is because of the variable vane turbos that are used on them. They literally build boost on idle and how the vanes variably adjust is why they make that nice clear spool sound through the entire rpm band. It can be replicated but wont be as clear on a gas like it is on those diesel trucks. With my cutout open I could hear the turbo pretty clear and wasn't really that loud considering. The turbo exhaust housing muffles the engine down quite a bit. Ever thought about just running an electric cutout?
Old 12-09-2012, 07:06 AM
^^^This exactly. And magnaflow ftw!
Quick Reply: What muffler/resonator that maintains turbine whistle?
