Which and what size turbo?
Old 04-29-2012, 08:24 PM
kbracing96's Avatar
The .70 a/r is the compressor housing, you need to look on the turbine side to see what the A/R of the turbine is.
Old 04-30-2012, 09:43 AM
turbo11z71's Avatar
I am not sure what the A/R on turbine side is, I think it is .68. I tried looking up the numbers off of the turbo at master powers site but they didn't match anything. It is a trick stage 2 kit so maybe he can chime in and give the specs of his kit. I will switch to a .96 and see what that does for me before I change the turbo. I am saving up for the triple12 cam now. The stall will have to wait a bit as funds are tight as always. Thanks for the advice and I will try and put it to good use. Can I order just the .96 A/R from master power or where do I need to look to get this.
Old 04-30-2012, 12:51 PM
Slowest turbo build ever!
black00chev's Avatar
^^^ Trick should be able to set you up with just the housing
Old 04-30-2012, 02:38 PM
mongooseboy000's Avatar
if u sell the kit let me know ill probably buy it. i been saving for a new kit and im almost there. i got an 08 silvy 4.8 that i want to boost!!!!!
Old 04-30-2012, 08:25 PM
turbo11z71's Avatar
I looked at the turbo today when I got home today and it is actually a .70 A/R and .96 A/R not .68 like I had thought. Now what?
Old 04-30-2012, 08:55 PM
Blak92's Avatar
Sounds like my 408 with the old tc76 and 1.15 housing, fell on its face after 4800. I went to a bigger turbine wheel, 1.10 housing s400 and same size comp wheel and on 2# less boost I picked up 10mph at the track and was able to turn it up to 5500, VE graph shows I could go further but not with the valve springs.
Old 04-30-2012, 09:35 PM
This would be your next step without buying a whole new turbo. Run the slightly bigger "Q-trim" turbine and 1.00a/r housing.
Old 05-01-2012, 04:32 AM
foose04's Avatar
His down-pipe wont match up with a BW turbo and if your changing turbine wheels i'd think your at point of just swapping snails. Best bet for a simple swap and little more lag would be a PTE 76gts/.96. Will mount up, 76mm wheel and a 75mm turbine. Wish I still had mine.
Old 05-01-2012, 07:25 AM
Blak92's Avatar
I wasnt saying he needed to swap to a BW, just that he neede a bigger turbine wheel period. I had to make up a whole new downpipe and the first 18" before the inlet flange to accomadate the larger (massive actually compared to the TC) BW.
Old 05-01-2012, 12:02 PM
02'Z71ONDUBZ''s Avatar
His down pipe won't match up to the MP70 1.0A/R Q-trim either, the housing is noticeably larger and has a 3.5" v-band. I will say though this turbo would probably satisfy you as the boost won't come in near as fast as with the .96 p-trim. I have been running it for awhile now and I also have experience with the .96 P-trim on a 5.3, and there is a significant difference in lag between the two. I can drive my truck anywhere I want without getting into boost. The only time I have trouble staying out of boost is when merging onto the freeway on a short ramp, or pulling a long grade on the highway with the converter locked at 60-65mph. The later is not so much of an issue though. I do understand your desire to be able to drive without ever getting into boost though. That was my reasoning behind choosing the Q-trim over the P-trim, along with a little additional hp potential, and I couldn't be happier with my decision. I think the MP70 Q-trim is the absolute perfect match for a 5.3.
Quick Reply: Which and what size turbo?
