what size turbo? 6.0
Old 09-23-2012, 10:56 PM
Restricted User
kalebm22's Avatar
Default what size turbo? 6.0
i need to know what size turbo i need, ill be going with a magnum. i just need to know size and exhaust size
this will be a stock cam and head 6.0 8psi
it is going in a 1970 chevy pickup on 38s
i have the t4 flange coming and my buddy will be doing alot of mudding with this setup so it needs to spool pretty quick.
also need to know what injectors work with a 2000 ish truck intake manifold and connectors. looking for 52 to 60lbs
thank you!
also found some 52lb injectors that have ev6 plugs and are the 1.75 heighth. what do i need to space them for the truck if i cant find a reasonable priced injector that just bolts/ plugs in?
Old 09-24-2012, 12:24 AM
Ferocity02's Avatar
Most importantly, what are your goals with the kit?
Old 09-24-2012, 12:46 AM
Restricted User
kalebm22's Avatar
just 8 to 9 psi. dont really have a hp number goal due to the big tires. but about 450 to 500 rwhp would be adequate.
Old 09-24-2012, 12:47 AM
Restricted User
kalebm22's Avatar
when i say 450 to 500rwhp that would be assuming stock size tires, this will also have a 4l60e behind it.
Old 09-24-2012, 08:33 AM
Silverad0 SS's Avatar
Front or rearmount?
Old 09-24-2012, 09:21 AM
Restricted User
kalebm22's Avatar
It is going to be up front, I'll be flipping the manifolds
Old 09-24-2012, 10:58 AM
Ferocity02's Avatar
No 60E will last long with 500hp, so be aware of that. An Magnum T70 will work; small size, will spool quick, won't make awesome power up top but should give you usable power down low for mudding around.
Talk to fuel injector connection about your injector needs. They will get you a good flow-matched set that fits for a decent price.
Old 09-24-2012, 11:33 AM
chevrolet all the way's Avatar
not true one bit
Old 09-24-2012, 11:56 AM
Ferocity02's Avatar
Originally Posted by chevrolet all the way
not true one bit
I meant to put a "not" in there, my bad
Old 09-24-2012, 01:53 PM
A magnum t-70 q trim with .81 A/R would be your best bet
Quick Reply: what size turbo? 6.0
