what size wastegate
Old 06-27-2009 | 09:37 PM
LsxCody's Avatar
Default what size wastegate
I'm getting a t70 turbo. What size wastegate do I need. Should I get a 60mm or would a 38mm be ok. Also if I only plan on running about 8-10 psi do I need a boost controller or just use the adj wastegate
Old 06-27-2009 | 10:08 PM
05crew's Avatar
38mm will be fine. and i would just get a 8lbs spring and boost ref. off the intake and call it a day.........
Old 06-28-2009 | 04:07 PM
thunderwagen's Avatar
38 will be fine, but if you plan on getting crazy with it later I would do a 44mm
Old 06-28-2009 | 06:14 PM
LsxCody's Avatar
Thanks for the help guys. I was looking at them and when they say adj from 8-12 psi. Does that mean I could run low boost then adj it up to 11 or 12 later
dsbodley
11-14-2015 09:46 PM
LSX-81-SIERRA
10-02-2015 07:05 AM
old motorhead
09-29-2015 08:22 PM
Closer_2001
09-24-2015 09:15 PM
Quick Reply: what size wastegate
