what turbo?
Old 04-02-2013 | 05:26 PM
  #31
AndysC3's Avatar
He's shifting around 6200 now. I agree that the BW 475 would be a great turbo for his setup
Old 04-02-2013 | 05:43 PM
  #32
nonnieselman's Avatar
I agree.. the larger turbine makes for a very nice top end.
Old 04-02-2013 | 06:53 PM
  #33
darnie's Avatar
ya, im shifting right at 6200. and ya i been reading about the t72 maybe alittle light on the top end ?
how good are these turbos?
http://www.ebay.com/itm/190814458809
http://www.ebay.com/itm/BRAND-NEW-HI...34735f&vxp=mtr
Old 04-02-2013 | 07:49 PM
  #34
Like I said buddy, if you are looking for budget, go with either of those two ebay turbos. If you are looking to just run 10-12 psi and want 500-550 rwhp the $260 68mm GT45 would work perfect. It will spool fast and is a proven budget turbo. If you want a little more but want to keep it cheaper, go with the 80mm GT45. Im running that turbo and it is absolutely sick. It is the same turbo Magnum sells for $1200 and works flawlessly. You will likely be damn close to 600rwhp @ 12psi with that turbo. And of course if superior quality is what you are looking for and can shell out the extra money, you cant go wrong with a T4 S475.
Old 04-02-2013 | 08:08 PM
  #35
Jake99's Avatar
Jake vs rudy - YouTube
Kind of a crappy vid but thats me with a 4.8 and a turbonetics 78-75 1.15 ball bearing turbo vs my buddys 5.3 with a bw s475 75ex wheel 1.10. We both nailed it at the same time with no brake boosting and mine pulled ahead almost 2 cars cause of spool time, but you can see he catchs me up top, the bw rips in third but is a vary laggy turbo compared to mine. Granted we are setup the same else wise other then converter.
Old 04-02-2013 | 08:12 PM
  #36
Jake, do yall both have the same converter, trans, gears, and tires? If not I don't think that's a very accurate comparison
Old 04-02-2013 | 08:14 PM
  #37
gamble686's Avatar
If you got the money go with the T4 S475. The only reason I can see not to is if you will need to modify the hot pipes to make it fit.
  #38
But badass video nonetheless haha!!
Old 04-02-2013 | 08:15 PM
  #39
I agree, you wont beat the quality of the BW, just have to pony up the dough
Old 04-02-2013 | 08:21 PM
  #40
gamble686's Avatar
5.3 more stall more cam and better heads. Vs jake99 I bet it would spool quicker in darnies truck.
