what turbo?
#33
ya, im shifting right at 6200. and ya i been reading about the t72 maybe alittle light on the top end ?
how good are these turbos?
http://www.ebay.com/itm/190814458809
http://www.ebay.com/itm/BRAND-NEW-HI...34735f&vxp=mtr
#34
Like I said buddy, if you are looking for budget, go with either of those two ebay turbos. If you are looking to just run 10-12 psi and want 500-550 rwhp the $260 68mm GT45 would work perfect. It will spool fast and is a proven budget turbo. If you want a little more but want to keep it cheaper, go with the 80mm GT45. Im running that turbo and it is absolutely sick. It is the same turbo Magnum sells for $1200 and works flawlessly. You will likely be damn close to 600rwhp @ 12psi with that turbo. And of course if superior quality is what you are looking for and can shell out the extra money, you cant go wrong with a T4 S475.
#35
Jake vs rudy - YouTube
Kind of a crappy vid but thats me with a 4.8 and a turbonetics 78-75 1.15 ball bearing turbo vs my buddys 5.3 with a bw s475 75ex wheel 1.10. We both nailed it at the same time with no brake boosting and mine pulled ahead almost 2 cars cause of spool time, but you can see he catchs me up top, the bw rips in third but is a vary laggy turbo compared to mine. Granted we are setup the same else wise other then converter.
