what turbo?
Old 04-03-2013, 05:14 PM
  #61
Exactly, its the nature of the beast, you have to give some to gain some. Larger turbine will spool slower but will make more power
Old 04-03-2013, 06:02 PM
  #62
darnie's Avatar
i dont think ill go over 12psi . and i have ls7 lifters already can you send me a link to the oil you guys run? thanks
Originally Posted by o2camaross
I would say if you plan to run 15+ just go ahead a do head studs and LS9 gaskets now. Its also a good time to put LS7 lifters in as well.
Old 04-03-2013, 06:05 PM
  #63
darnie's Avatar
i think i want a turbo 700hp supportive max but that will spool up quick without falling on it butt up top. i think the turbo ur running would do that?
Old 04-03-2013, 07:41 PM
  #64
Mine prolly makes close to 700rwhp on 15psi, its capable of much more too. If you want to stay at 12psi and make 700 flywheel hp, roughly 550 rwhp, I would say go with the $260 68mm GT45. Itll spool nicely and make that power with no problem
Old 04-03-2013, 08:08 PM
  #65
darnie's Avatar
ill prob end up getting the one your running? i jsut dont know what specs ect to get... ?
Old 04-03-2013, 08:42 PM
  #66
Jake99's Avatar
Valvoline.com > Products > Racing > Racing Motor Oil Racing > VR1 Racing Oil (VR1)
Old 04-03-2013, 10:36 PM
  #67
darnie's Avatar
sweet thanks jake. what weight are you guys running ?
Old 04-04-2013, 08:08 PM
  #68
darnie's Avatar
as far as the turbo goes is there just one sized 80mm? or is there one that has a different AR , exhaust or what not that will help/ do different than the rest?
Old 04-05-2013, 06:21 PM
  #69
darnie's Avatar
would these be good springs to run with the kit?
.660" Lift Extreme Spring Kit with Tool Steel Retainers - Brian Tooley Racing
Old 04-05-2013, 06:26 PM
  #70
GMCtrk's Avatar
Yes. I have those except with titanium retainers
Quick Reply: what turbo?
