what turbo?
Old 04-05-2013 | 08:06 PM
  #71
gamble686's Avatar
Motor upgrades for boost: LS9 head gaskets, arp rod bolts(above 12lbs), gap piston rings(above15lbs), trunion upgrade, LS2 timing chain and gears. Oh and proper spark plugs.
Rearend:trutrac
Trans:freshen up the trans, add a shift kit and let her rip.
Fuel: Walbro 400/450, and biggest injectors you can afford.
Other suggestions for the build.
1) shorter tires, crank the keys down, and remove the rear blocks.
2) get to a track get some baseline times to compare the boost results to.
3) a change of pants for the first time you go wot.
4)Also you need to get a boost gauge in there too.
5) get a real exhaust with a good muffler.
Old 04-05-2013 | 09:46 PM
  #72
darnie's Avatar
you think i should pull the gaskets again? i can keep it around 10psi if need be. plan on doing the truion upgrade, need to get a chain, and what gears should i run? what spark plugs? im running ngk's right now. rearend is a deff maybe down the road. tranny will get rebuilt later on" pro low boost till then" and im still looking around for fuel and new valve springs.
1- i may do that if not im looking at 33"S on 18's
2-one day.... lol prob not a option cuz of the new job
3-all the cool kids poop there pants so eff it!
4-im prob going to get a new dm-6 and see with i can do for boost, fuel, and oil pressure?
5-im planning on a magnaflow d-max muffler.
Old 04-06-2013 | 11:43 PM
  #73
darnie's Avatar
Well i picked up the kit should be fun now just gotta get the rest of this stuff! Haha
Old 04-07-2013 | 10:54 AM
  #74
good deal man!! Let me know if you need anymore help
Old 04-08-2013 | 02:28 AM
  #75
darnie's Avatar
for sure man, im sure ill be hit'n you guys up soon haha. it maybe a few weeks till i can get some more stuff. gotta get a few things done around the house. but shouldnt be to long
kha4079
10-29-2018 05:38 PM
lxcoupe
09-06-2017 09:24 AM
jtphelps289
09-11-2015 07:37 PM
slowswb
09-05-2015 03:27 PM
06murder
09-04-2015 04:54 PM
