What turbo lag?
Slowest turbo build ever!
Size the turbo right and the turbo will make full boost almost instantly. Just might run out of steam a little early. And even something a little big should atleast start making boost instantly, just might take longer to hit max. Think about some of the diesels for instance. Those turbos seem to hit max boost almost instantly.
And like you said, no crazy belt systems to worry about or fancy exhausts needed.
Tin Foil Hat Wearin' Fool
Have you driven a diesel? They're laggy as hell, from a flat foot on a 150 Efi tune my lbz wouldn't hit full boost til the far side of a 4 lane intersection. Sure it came out of vacuum quick but the powerband was like a slingshot. Wouldn't leave black marks for about 30' but after that on 35s it would start getting squirrely. I hated that powerband which is what I'm trying to get away from.
I suppose the lag debate is like what cam or converter is too big. I like my gratification instantly.
Come on Richard get us a video from a dig with no brake boosting.
I like a little more lag myself. The little 68mm turbine was ok and spool real quick on my 6.0 but its only good if I was 17 again and do rolling burnouts in front of the sonic to impress my friends... Ha ha ha. When I swapped to a 75mm turbine I loved it so much more. Still spooled quick and the power and spool in 1st was only a traction aid somewhat. And the power gain up top was crazy. Felt like 100 HP gain with a couple # LESS boost...
9 Second Truck Club
