Whats the best size blower for a 434? 2.8 or 3.6 KB?
#22
#24
#25
I think you will find the intake tube will be a tight fit once you install the throttle body to clear the alternator, especially since it is lifted and moved over to clear the blower. I relocated my battery and built a new box to keep the intake on the drivers side with my 2.8. With a 45* bend directly off the throttle body, the tube is very close to the terminal on the alternator.
Just curious, what else did you have to clearance besides the alternator for the 3.6L to fit?
#26
Might not be able to flip cause of the bypass.
I like BigKID's idea, would.
Just put the battery in passenger side corner and air filter in the driversides corner. Easy to reroute wires. I think it would be a very clean look..
#27
Are you still running the 28" radiator? I just ran my air tube to between the ratiator and battery and the just 90* it down, removed the rubber flap thats there and put the filter pointing down so it gets fresh cold air from there.
#28
#29
#30
Good looking setup. Im in the process of building a forged 370 with a KB 2.8 and will be doing about the same setup you have there. I'm going to relocate the battery to the other side so I have a bit more room. That looks sick dude, it inspires me a little
