Where did I go wrong?
Is that the timing you wanted and were commanding on the high/lo timing tabel? The only way to know whats wrong is to pull the head or use a scope to look inside. With that 7psi boost and 29* of advance is a lot of cylinder pressure and it broke the piston hence the knock you now have.
Is the stock truck intake a problem? Should i be looking into a different intake when i do a rebuild? What else do you guys think? I was thinking some good pistons, a mild cam, and some hardened pushrods. Or maybe just drop in a used 6L?
How do I change this text
The LQ4 pistons seam to hold up a bit better, but push them too far and you will be right back were you are now... look at my avatar, those are LQ4 ring lands...
I think he was refering to stock manifold FI (ie, turbo, cent blower etc) Radix uses a different manifold and is a little better than the stock manifold when it comes to #7.
