where the hell is my oil
Old 03-25-2010, 10:12 PM
Banned Scammer
scotthughes's Avatar
Default where the hell is my oil
Ok. So I got home from work last night and the three weeks I was gone I had it turboed. Well. Long story short we drove it from EARTH MOTORS shop to his other shop with It tuned good enough to drive the small distance, maybe five miles. He tuned on it a little more and we were about to dino tune it and drive it one more time for him to tune on it. Mind you It was never gave more then half throttle while driving it. Then it starts knocking...la the motor is being pulled tonight. But when the oil was drained there was at the most three quarts of oil in it. Mind you the oil was changed when the turbo was done, about 10 miles ago. When it drained there was also some kind of white film that came out with It. So my and the oil did not come out the exhast. I checked. O
Old 03-25-2010, 10:16 PM
Dewey's Avatar
leak in the turbo's oil system maybe?
Old 03-25-2010, 10:17 PM
2004SSS's Avatar
you check the intake piping ? you check your coolant ? the film could be water but usually that makes it nasty milky ish.
Old 03-25-2010, 10:18 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
New or used turbo?
Old 03-25-2010, 10:19 PM
Banned Scammer
it did not come out the exhast, so where did it go and what was the white film?
Old 03-25-2010, 10:24 PM
outlawz2004's Avatar
sounds like water. Head gasket possibly. Check your coolant and see what that looks like. Are you sure the oil was filled all the way before driving it.
Old 03-25-2010, 10:43 PM
Banned Scammer
Brand new turbo from presicion. Oil was filled all the way. And No oil leaked out externally.
Old 03-25-2010, 10:52 PM
kbracing96's Avatar
Must be magic! If it didn't go out the exhaust and didn't leak out the engine somewhere, then it just VANISHED!!
(has to go somewhere bud, keep looking or it wasn't filled )
Old 03-25-2010, 10:57 PM
Banned Scammer
Yeah... I have no clue. Its kinda mind screwing. Three quarts...you would think you would notice it coming out...
Old 03-25-2010, 10:58 PM
2004SSS's Avatar
you did check the intake piping correct ? you keep wording it exhaust but there is a seal on the cold side as well and can blow through to the intake.
Quick Reply: where the hell is my oil
