Whipple 3.3L "tuner" kits for LS1/2/6
Old 01-26-2006, 01:13 PM
MOOBIES Moderator
Scream's Avatar
Default Whipple 3.3L "tuner" kits for LS1/2/6
I hope this isn't a repost. I saw that Sean and the guys at Speed Engineering were working with Whipple on a top-mount setup, but I just went to Whipple's site and saw this:
http://www.whipplesuperchargers.com/...sp?ProdID=1230
Old 01-26-2006, 01:30 PM
ranwalk's Avatar
It's been out for a lilttle while, but nowhere near a direct bolt on. I hope that speed eng and whipple work out together for a bolt on application as complete as the Radix. If so, then my plans for this year will change quite a bit
Old 01-26-2006, 04:38 PM
Exclamation
I thought they were going to make it a complete bolt on kit???
That's the kit I want!!!! Will buy it after tax return and if it's available as a complete start to finish bolt on kit!
Looks as though I will need a frigin hood, traction bars, slicks with that one!!
Jim
Old 01-26-2006, 05:16 PM
99Silver6.0's Avatar
Fat!! Look at the belt on that ******!
ALSO... That thing looks major tall!!
Old 01-27-2006, 02:08 AM
IslandTahoe's Avatar
Now I would cut my hood for that....
but the application in the pics seems to be a sand rail with the motor facing the rear. I don't see any alternator, at least where our trucks mount them. I hope they make it a complete bolt-on kit, but I got to believe that would be a long shot. Tuner kits at the most.
Funny how they put a note specifically saying that this will not fit under the hood of a C5 vette...I don't think it will fit under our truck hoods, let alone a C5 or F-Body.
Old 01-27-2006, 07:56 AM
it's $9000 and will ship in 3 weeks. Just got an email back today. that's with no heat exchanger but with 10 rib setup.
Old 01-27-2006, 08:17 AM
here's a better picture of the gm efi tuner kit. i think there might be 2 different kits available.
http://www.whipplesuperchargers.com/...sp?ProdID=1172
Old 01-27-2006, 08:29 AM
Why aren't you going with a heatexhanger?With the heat exchanger you can run about 14-16lbs of boost.The supercharger can produce 25lbs.
Old 01-27-2006, 08:35 AM
MOOBIES Moderator
Scream's Avatar
The one that you posted a pic of is a SBC, not a GEN III motor. Still sweet though!
Old 01-27-2006, 09:03 AM
ranwalk's Avatar
No way I'm dropping 9 grand for an incomplete kit with no heat exchanger. I may be switching to a Procharger afterall
Quick Reply: Whipple 3.3L "tuner" kits for LS1/2/6
