Whipple with 43lb injectors
#21
Are you going to crank up the boost more? If not you don't need the pump. It takes the same volume of fuel to supply a 400hp engine with 42lbs as it does with 31lbs injectors. The inline fuel pump is a good safty measure though. I have herd good things about flex fuel pumps they are supposed to be quiet, a bolt in and flow a buttload of fuel. I can't find a conversion chart that goes from buttload to gpm yet.
#22
Originally Posted by quicksilverado
Linda, I would think that the fuel pump used for the 8.1 is capable of pushing more fuel than the pumps used for the small blocks.
whippledstepside
09-17-2015 05:02 AM
scooter k
09-16-2015 10:32 PM
