Whipple with 43lb injectors
Old 06-19-2006, 11:58 PM
  #21
Dirty Dave's Avatar
Are you going to crank up the boost more? If not you don't need the pump. It takes the same volume of fuel to supply a 400hp engine with 42lbs as it does with 31lbs injectors. The inline fuel pump is a good safty measure though. I have herd good things about flex fuel pumps they are supposed to be quiet, a bolt in and flow a buttload of fuel. I can't find a conversion chart that goes from buttload to gpm yet.
Old 06-20-2006, 12:00 AM
  #22
Dirty Dave's Avatar
Originally Posted by quicksilverado
Linda, I would think that the fuel pump used for the 8.1 is capable of pushing more fuel than the pumps used for the small blocks.
Check part numbers you might be surprised!!
Pimpinpete
43
12-22-2017 08:13 AM
OHsixLS3
09-25-2015 11:20 AM
whippledstepside
09-17-2015 05:02 AM
scooter k
09-16-2015 10:32 PM
jroctpb
09-16-2015 09:05 PM
Quick Reply: Whipple with 43lb injectors
