whipple and boost probelms
my buddy has a whipple on his 03 single cab and it is a used whipple.... its a 4.8 bone stock except air intake. i dont know what the whipple comes stock as far as boost whise but it is only making 2lb's..... timing is 18* at WOT and injector's are at about 97% at 6300, anyone have any suggestions why ?
What is his afr? Has it even been tuned? Did he plumb the bypass solenoid right? My guess would be tune and solenoid wiring. I helped a friend install one on his truck and it only made a couple of pounds of boost till we wired the solenoid to a 12v source with a toggle switch
8 Second Club
drop the whipple electronics, add 42 pound injectors, a boost a pump and 12 volts to the bypass. Mine is like Old Bull talked, I call it a valet switch. No juice, 2-3 pounds. Juice, 7 punds.
8 Second Club
how much boost were you pushing charcold? also, were you using a boost a pump?
at 7 pounds, I was starting to go lean at 5000 rpms. We realized it was due to pressure drop. The boost a pump fixed that.
How much were you putting down? I always wondered how much power the 42s could make.
whippledstepside
09-17-2015 05:02 AM
scooter k
09-16-2015 10:32 PM
