Who ended up with my 122?
#21
I believe it did, as well as the Dr X harness to plug and play, but i have a TBSS tb as well. Was going to use one of the 2. I probly will keep that tb that you had. I think as far as the injectors go i will be good to go as soon as i get the new ends for my harness on.
#22
the reason i got rid of it right away is because it wouldnt be able to huff enough for my 408 setup with 9.5 to 1 comp. I only seen 4 pounds max with it. Thats why i had to part with it right away. As for my current setup. its been a very very long road, I put new WCCH edelbrock heads on, and the first run it pulled the rocker arm stud out, so put an oversized helicoil in it. then when my builder ran it. he brought it up to RPM in gear a bit. made roughly 2 revolutions with the tires and f*cked the ring and pinion in my new rear end. but i just got called today and was told that it was put back together again. my god i cant wait for this to be over with....
zblee
11-11-2015 12:41 AM
thompson
09-30-2015 09:48 AM
