I started to have a small amount of coolant along side block/head at 17-18psi and 17 degrees timing on stock bolts/gaskets. Nothing was mixing though and coolant overflow didn't move. I did studs after I noticed it.
I'm almost willing to bet that once studded the percentage of boosted 5.3/4.8 to head lift is lower than 6.0+ of the same. I'm just asking to get an idea. Not that everybody in the world with boosted 5.3's are on here but still.
I popped a head gasket on my 5.3, but it had 175,000 miles on stock composite gaskets with stock head bolts. Boosted since around 100K. I'm actually surprised that it held as long as it did.
You'd be right.. Less area to push against so less stress on the head. That's why studs are even more critical on 6.0s.
Could always go 1/2" on the studs...lol. Strokers are inherently better for fuel efficiency as you've probably read, so if thats what you're going for then I'm in for results.
