who makes a decent intercooler?
i dont know what model it is. is there a number plate somewere on it that i could check ? ya i was thinking of putting a normal intercooler on it but you say its a water to air system so under the supercharger would be like a evaporator type deal? but that would make sense because i remember i was rootin around in my engine bay i found what appeared to be a rad hose but had gotten to close to the crank pulley and ripped it open and i think it went to a magnusun resevoir so that would make sense so if i fix it what would i fill it with glycol and water because it do live in alberta canada and it is winter time. thanks
Yes, those blowers have a liquid to air inter cooler with the heat exchanger in the manifold under the blower. If you cut the hose and lost all the coolant, then it is obviously not going to work very well, you need to fix the hose and probable replace the fluid pump attached to the bottom of the Magnuson reservoir, as it is most likely burnt up from running without any coolant. Refill the intercooler system with antifreeze and you intercooler will be functional again.
all fixed and shes pumpin cooling through it like no tommorow but i just used a generic pump that i found and i has a lower GPH than the bosch one so i think ill try and find the right one but its not as easy as one might think i went to every parts store i could find but no luck anyone know were to get that thing from even with the part number everyone was useless, also anyone ever try one of those nitrous cooler chillers on that rad? could be fun
thewrx
08-12-2015 08:28 PM
