Will I gain anything from this?
11 sec. Truck Mod
HellbentS10 has a 90mm Jtube for 150$ in the classifieds, i'd be all over this if i needed one. Not pimping, just letting you guys know whats out there.
I would def. upgrade the Jtube and Throttle body, it works for everyone who does it and tunes for it. Bigger the better!
You will also more than likely have to upgrade your injectors if you have not already.My injector duty cycle is at 98 percent now with the 78 MM and you having a 6.0 will definately max out 42 pounders.
Excuse the multi-quote feature---
Great link, thanks for sharing! I'm very impressed with your truck. You can really tell it's making some power in your vids.
I'm with you on that. I want to go faster and I do want to eek out what I can from this combo, but I'm planning on a 427/tvs 2300 soon and don't want to throw a bunch of money away on mods if they only pick me up a .10. Know what I mean.....
Wow, what a huge difference! Why does the 90 j-tube only have 4 bolts instead of the 6. Did the powers that be see fit to grace us with a little less aggravation when working on it or something -- lmao!
I'm assuming this is pretty involved as far as the tuning. Pretty much a whole new tune session. Is it hard to get the map dialed back in and how far is everything off typically. In other words, I'm not a professional tuner. If it takes Joe Professional a couple of hours tuning my truck, it'll take me 2 years tuning it.
From your sig, you're running a bigger motor and blower? 2.5" restriction and you picked up 3psi when you opened it up?! OMG! I could only hope to pick up that much........I think most guys on these blowers only pick up a tenth or two with this mod......Not sure, that is what I was trying to find out on a truck at this level....Thanks for the feedback.
I just pm'd him----thanks!
Yep, I was actually maxing out my injectors before. I have meth injection now and I'm very safe (around 90% iirc).
Love eye candy. Post up!
Read my thread here. https://www.performancetrucks.net/fo...-mp112-485856/
It's a very worthwhile mod, in my opinion.
Side by side throttle bodies(to show the difference in size).
Check out the difference in the j-tube openings.
This is the stock Maggie air inlet tube, on the MAF side. Small.....
The stock MAF is also small, around 3.25" inside diameter IIRC. My opinion, get rid of it, go 4" all the way. The stock airbox lid is 4" by the way.
