Will I be happy with a Trick kit?
#21
I'd actually love to try and build a DD friendly turbo setup. I would keep things very simple and go for maximum responsiveness. An S366 on a 5.3 non-intercooled with a 4" downpipe into a 3.5" catback (something that could stay more quiet than 4" stuff). TR6 spark plugs, stock cam, eveything else. Would make for an extremely fun setup I would imagine that could pump out 500 rwhp on 93.
#23
Im looking for 11's out of mine. My LB7 runs 12 on 35's so I'd be upset if the rcsb won't out run it. I figure truck will come in at 5200 lbs so 550rwhp ought to be sufficent for my goal. Can the stage 2 trick kit, 80 lb injectors, walbro 450 and a tripple 12 acheive this? Trans will be built with a complimentary converter to the turbo setup.
#24
#25
Stock cam just because I would be lazy and because aftermarket wouldn't be needed to reach 500 hp goal.
Would run straight 93 so I could fill up anywhere, and shoot for 10 psi.
Goal would be for the truck to be utterly stockish with around 250 rwhp added.
#28
What do you think the IATs would be with no intercooler?
I would want a smaller turbo for faster spooling correct?
Im thinking that ether way if I go 6.0 or turbo 4.8 I will toss in a ISKY triple 12 cam. That is unless someone has better suggestions.
#29
Non-intercooled for much shorter piping and no pressure drop across an intercooler. All about the best turbo response essentially.
#30
My vote is a turbo kit. I have a Trick stage 5 deal, which I see in't on the website anymore??? The kit was pretty good, I had to modify it because my truck is slammed, so I brought the cross over up 3" from what the kit was originally, BUT I have a TH400 that doesn't have a full bellhousing like the stock transmissions. Being a 4x4 and not slammed, you are in the clear I would say!
-Kenny
-Kenny
