will the lq9 spool? LBRmotorsport..
Old 02-22-2013, 06:32 PM
gallo-lo's Avatar
Default will the lq9 spool? LBRmotorsport..
Will the stock lq9 with 317 heads spool a 80 mm t6-1.83ar ?? Lol
Hey forums, I'm still haven't started in the motor department yet, just gathering parts to the shelf, for my 02 Sierra 2wd SB .
Working on rear suspension 14 bolt -4:10, coil spring conversion, still need more parts ..
My goal is the 700hp mark,will the lq9 spool a big turbine on the street on e85??, will be working on a th400 ..
I still want to keep stock compression10-1 n 317 heads some porting, edelbrock Intake ,freshen lq9 New berings, arp bolts, z06 cam,125hp NoS shoot.
Old 02-26-2013, 07:46 PM
xx_ED_xx's Avatar
at about 6000 rpm
Old 02-26-2013, 08:06 PM
03regcab sierra's Avatar
How big is the turbine wheel? Most likely u will want a smaller exhaust housing
Old 02-26-2013, 10:20 PM
Hunt&Fisherator
silver-mod-o's Avatar
You're not gonna want 4.10's either...
Old 02-28-2013, 10:46 AM
M&M Turbochargers's Avatar
i know a guy running a 6.0l spooling a BW s480 with a 1.32 housing,,and a 96/88mm turbine wheel
edit front mount
Old 03-01-2013, 09:20 AM
gallo-lo's Avatar
Originally Posted by xx_ED_xx
at about 6000 rpm
I don't think so, ill be bumping CR to almost10.5 .. e 85 zr1 cam.
Old 03-01-2013, 09:22 AM
gallo-lo's Avatar
I've seen back pressure issues with a 1.32 t6 housings on some of these engines.. they flow!!!
Old 03-01-2013, 12:12 PM
quicksilverado's Avatar
t6 with a 1.32 is way to big for a rear mount set up. It will have a ton of lag.
Old 03-01-2013, 12:30 PM
gallo-lo's Avatar
So what you suggest? T4?
Old 03-01-2013, 01:40 PM
t4 76 .96 ar will spool much faster and get you about 650-700 rwhp.
Quick Reply: will the lq9 spool? LBRmotorsport..
