will this turbo make 500-550rwhp?
Old 12-28-2012, 03:57 PM
greenturtle05's Avatar
Default will this turbo make 500-550rwhp?
I bought an ebay GT45 turbo with the intentions of putting it on a lq9, with can and springs. This will be my first turbo build, so I'm not looking for much. Anything in between 5-600rwhp will be great for now. This won't be going in a truck,but it will be for streets. I know it's on the small side compared to what I've been reading others have. Thanks in advance
Specs Compressor Size: Inlet = 4 3/16", Inducer = 68.7MM, Exducer = 97.8 MM, Trim = 69,A/R = 0.66, Intake (ID / OD) = 2.25" / 3.25"
Turbine: Outlet = 4", Turbo flange = T4, Downpipe flange = 3.5" V-band, Inducer = 87.4 MM, Exducer = 77 MM,Trim = 92, A/R = 1.05
Old 12-28-2012, 04:14 PM
lglowe's Avatar
I would say so. Should spool good too
Old 12-28-2012, 04:16 PM
bk_cauley's Avatar
wrong on the spool. i just got rid of one of those. didnt even think about spooling good until 35-3700.
Old 12-28-2012, 04:20 PM
12 Second Club
Funkster's Avatar
The power should be there. What PSI are you planning on?
Old 12-28-2012, 05:20 PM
I was thinking around 10psi.
Old 12-28-2012, 05:36 PM
Alpinestar's Avatar
Where you running it on a 6.0l?
Other things can effect how a turbo spools as well, such as the gearing and stall.
Old 12-28-2012, 08:04 PM
formery SilverSleeper1500 (12-06-2011)
Dbyers2's Avatar
1.05 A/R Housing on the turbine is a little big for a 68 mm turbo but it definitely has the power potential off 500+ hp depending on other mods though
Old 12-29-2012, 01:46 PM
UnVmy5.3's Avatar
my 5.3 mustang put down 515hp on 10# mine was fully spooled by 3000 rpms, i just bought another on for the truck, also there is alot of guys on ls1tech making 700hp with one of theses
Old 12-29-2012, 08:59 PM
M&M Turbochargers's Avatar
a 6.0l will have no problem spooling a GT-45,, we have one a 350 sbc in a vega and is the best bag for the buck turbo out there
Old 12-29-2012, 09:07 PM
All the ones i saw in that power range were 4.8and stall5.3's. No 6liters . What size stall were you running ?
Quick Reply: will this turbo make 500-550rwhp?
