Worlds quickest and fastest stock bottom 4.8 finally went BOOM details inside
Old 08-20-2012, 07:42 PM
lglowe's Avatar
Need one from a 05-07 to have the good rods and be plug and play. Some of the 04s have em but there's no way to tell without opening it up
Old 08-20-2012, 07:45 PM
lavoy's Avatar
ok so 05 will be plug and play then? good thats what i will look for.
Old 08-20-2012, 07:47 PM
03regcab sierra's Avatar
I think they changed reluctor wheels in the gen 4 iirc. 99-06 should all be the same. In for details as to why it let go..
Old 08-20-2012, 07:50 PM
lavoy's Avatar
my cam is also ruined so if any one knows wher ei can get a 02-04 ls6 cam and lifters please speak up. not sure why it left go, i was running more boost then it was dynoed at but the afr still looked good , and it was the last two cyl so im guessing maybe the meth dont get to the back two cyl as well as the front and middle ones. she ran a bunch of passes at this boost level and went a 9.24 at 150 as a best.
Old 08-20-2012, 07:51 PM
10 Second Club
GONEB4U's Avatar
05-06 For sure are the better rods and still 24x Reluctor wheeled.
Old 08-20-2012, 08:08 PM
Mod with training wheels
smokeshow's Avatar
the cool thing about a 4.8 is they can be replaced for $400!
Thats how much mine costed
Originally Posted by A Low Dime
2004+ I believe have the beefier LS2 rods. Possibly 2006+.
Originally Posted by lavoy
thanks! can any one else confirm?
Yes, 2004 and up engines have the beefy rods. However, not all MODEL years have 2004 engines. 2004 trucks can have engines manufactured in 2003. If you want to be safe, best to look for an 05 and up engine.
Sucks that it blew...get a newer one in there for a couple bucks and give it hell. I want to see where the LS2 rods give out... I took mine to 22psi before I pulled it out in good condition to replace with a 6.0. She's still waiting on an engine stand as backup
Old 08-20-2012, 08:13 PM
I have an ls6 cam for sale with less than 3k miles on it Ill sell for $250. Was thinkin about using in my 4.8 build but now i want to go with a custom grind.
Old 08-20-2012, 08:18 PM
Of course my 04 would be one with the weaker rods haha. Good luck buddy
Old 08-20-2012, 08:43 PM
foose04's Avatar
Busted #7 gives me a little hope on it being a heat/tune issue but the bent rods is a tough one.. lol
How was the air/fuels and what kind of timing did you have to the girl?
Best of luck on the next one and mind sharing the some pics of the rods?
Old 08-20-2012, 08:46 PM
lavoy's Avatar
it was both rear cylinders not just number 7 i didnt post a pic of the other cause it looked the exact same. i forget the timing we put in it but it was considered a safe number at 17 psi but i was at 19 for a while . afrs are around 10.9. all the rods are bent, this probably lowered my compression even more allowing it to live at 19 as long as it did. my theory is the meth dont get back there as well with the fast intake. i plan on adding a half to full ib of fuel pressure with the new set up since i dont own hp tuners , that should richen it up a little more.
Quick Reply: Worlds quickest and fastest stock bottom 4.8 finally went BOOM details inside
