Worlds quickest and fastest stock bottom 4.8 finally went BOOM details inside
#53
not sure on the power level, on the dyno the car was spinning, the converter was blowing threw and we suspected valve float from the single PAC springs so the dyno read just over 600 whp at 17 psi but the graph was all messed up from the problems. its been running 19 psi since then, based on weight and MPH id have to guess it was actually over 700 whp.
#55
unless I missed it, you never mentioned what turbo and size you were running on it??? I have a 2005 4.8 that I am building... I would love to know... (What injectors also were you using?? Wastegate??) I have a 50mm tial BOV, LS6 intake, i need a TB, debating on if I should use a LS6 cam or go with a custom turbo cam. I also have a LS2 timing chain and ported LS6 oil pump...
I just hope it will all work out once I find a cam and injectors....
