Worlds quickest and fastest stock bottom 4.8 finally went BOOM details inside
Old 08-21-2012, 10:01 PM
  #51
lglowe's Avatar
How much power was this thing putting down?
Old 08-21-2012, 10:41 PM
  #52
Slowest turbo build ever!
black00chev's Avatar
Steve is great.. might use him for my truck since hes just a little under 2hrs from where I live.
Sucks to see the engine let go but damn was it pushing that car fast!
Old 08-22-2012, 07:30 AM
  #53
lavoy's Avatar
not sure on the power level, on the dyno the car was spinning, the converter was blowing threw and we suspected valve float from the single PAC springs so the dyno read just over 600 whp at 17 psi but the graph was all messed up from the problems. its been running 19 psi since then, based on weight and MPH id have to guess it was actually over 700 whp.
Old 08-22-2012, 02:55 PM
  #54
black4.8's Avatar
sad to see a 4.8 die, but it had a hard life.
Old 08-22-2012, 07:25 PM
  #55
AlterEgo's Avatar
unless I missed it, you never mentioned what turbo and size you were running on it??? I have a 2005 4.8 that I am building... I would love to know... (What injectors also were you using?? Wastegate??) I have a 50mm tial BOV, LS6 intake, i need a TB, debating on if I should use a LS6 cam or go with a custom turbo cam. I also have a LS2 timing chain and ported LS6 oil pump...
I just hope it will all work out once I find a cam and injectors....
thunder550
10-08-2015 04:53 PM
black6spdz
07-16-2015 01:32 AM
gavin2005
07-16-2015 12:09 AM
fcompean
07-15-2015 09:55 PM
kdw8888
07-09-2015 10:52 PM
Quick Reply: Worlds quickest and fastest stock bottom 4.8 finally went BOOM details inside
