wow! 919hp @ 10lbs of boost!
#63
As long as there is positive boost, the blower can not be a restriction. The old way of big motor (427) and max blower speed, makes a ton of lower to mid range torque, but the blower runs out of breath before you can get to the high RPM to make the high horse power numbers.
A 2300cc blower can only move X amount of air (either in lower RPMs or higher RPM of motor speed) before it becomes extremely inefficient and just blows hot air. So you pulley the blower speed where you want the good air. (high engine RPM makes high horse power)
#64
The engine has all Jesel Solid Roller valve train. It can also be spun alot higher with the shorter stroke. This way we can test different options on builds and supercharger packages. We can use it to see where the airflow peaks and then back build the package to the intended operating range. What we are playing with is letting the rotor speed match the airflow in testing. We hope to be back on the dyno again in about 3 months.
#67
I am really looking forward to the next round of testing where we will be able to see it really shine in the higher RPM's. Maybe a peak at over 8000 RPM's and she should really scream.
#68
I understand the curiousity but the engine was only built for boost. The compression, cam and heads are not where it would need to be for an N/A max effort.
#69
I agree. I've always figured 20 to 25 hp increase per lb of boost on a belt driven blower. The Heartbeat seems to be high side of that unless this motor is making really stupid power n/a. I didn't see meth mentioned. On the previous TVS units, my impression was that meth added octane, but did little to cool the IAT's. Maybe stave off heat soak. Was meth used on this one? Race gas?
#70
I am really unsure what the engine would make for power with a standard intake N/A. Maybe we can set up an N/A test the next dyno session just to see where it is at. Remember this combination wont peak till well above 7500 RPM's.
We really need a supercharger that can push the upper limits of the engine as it was designed, that is where it should really shine.
