Wrapping the log and DP?
Old 01-20-2010, 09:18 PM
KRestevan's Avatar
that thread title is perfect for the "forced induction" forum
Old 01-21-2010, 12:27 AM
TURBHOE's Avatar
While I was doing some turbo reading I found some interesting info. In short it said wrapping the manifold and what not is good but not the DP. Reason being is, if the DP is cooler than the manifold feeding the turbo i.e. it’s aired out by not being wrapped, the heat will expand to the cooler DP (or some ****) and make the turbo spool faster.
Ok so I can't word it like they did when its 1 in the morning. But in short, short it makes the turbo spool faster by helping the heat transfer help spool the turbo. Has to do with the expanding gases crap.
Old 01-21-2010, 12:43 AM
LsxCody's Avatar
Originally Posted by denali_on_26's
i always wrap my log before i DP that biatch...
i was like wtf........btw my log and dp are wrapped as well,along with the driver side manifold.
Old 01-21-2010, 09:46 AM
Coban's Avatar
This is true. You want to conserve heat before the turbo, remove it after. This is why wrapping the crossover makes the biggest difference (its thin wall, cools faster) On the other hand, colder air in the downpipe will reduce backpressure.
Old 01-21-2010, 11:05 AM
LsxCody's Avatar
interesting
Old 01-21-2010, 11:37 AM
Rick_Vor's Avatar
Makes sense. I've read the same thing on a few other forums. I think for my truck, I'm still going to wrap the DP's in the engine compartment. I think my exhaust is free-flowing enough (two 3" DP's, 3" madrel pipes/X-pipe, two 3" Random Tech muffs, two 3" tailpipes) that I'll take the reduced under hood temps.
Rick
Old 01-21-2010, 04:05 PM
Slowest turbo build ever!
black00chev's Avatar
How much are you guys spending on wrap to do all this? Just seems so much easier and cleaner to get the pipes coated.
03sierraslt
11
10-27-2015 03:38 PM
GMCtrk
10-20-2015 06:17 AM
Wolftrk99
10-02-2015 08:17 AM
murderedSS
09-27-2015 10:16 PM
Quick Reply: Wrapping the log and DP?
