WTF?!? I keep blowing oil pump fuses!
Old 09-09-2006 | 11:24 AM
vanillagorilla's Avatar
I'm not sure yet. I haven't really driven it much. I think I have a bad O2. My initial log showed that it was barely reading. Yesterday after I fixed the ground and did the plug wires it ran great. It felt like it had more bottom end than my old cam, yet it took off around 4000rpm like my old cam. Anyway, today it would barely idle and my O2 sensor wasn't reading again. Boo....
Of course, that bank could be reading lean because the injectors aren't firing properly. But then again I'd be getting some KR too and I'm not at all.
Old 09-09-2006 | 11:28 AM
...sounds like another battle, good luck man, i hope everything works out well for you.
Old 09-11-2006 | 01:59 PM
My speculating was right. It was a loose injector wire, causing bank 1 to run lean. Oh well, easy fix and it didn't cost anything. I must say though, this cam is a ton better than my old one. It has way more bottom end! I haven't boosted past 2psi as I am still tuning, but I can feel and hear the turbo spooling faster. Plus a smooth idle at 700rpm is a lot better than a rough one at 900-950 rpm and only 9" Hg of vacuum.
Old 09-11-2006 | 06:43 PM
kbracing96's Avatar
Its a nice, CHEAP cam
Old 09-11-2006 | 06:46 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by kbracing96
I told ya!
There's 2 different length plug wires, ask Chris how he knows this
Shhhhhh!!!!!
Old 09-14-2006 | 09:56 AM
onyx's Avatar
14 Second Truck Club
good to hear it got running Todd. i'll be home sept 20th. we need to check some of my **** out.
Old 09-14-2006 | 11:11 AM
Now if I can only get the 3 bar MAP to work.
Old 09-14-2006 | 12:33 PM
BlownChevy's Avatar
blownerator
I miss you
5.3Okasai
03-09-2022 02:07 PM
chopperloco
07-10-2016 11:45 PM
JordanH
08-08-2015 08:59 PM
Ammadien
07-22-2015 09:50 PM
Ferocity02
07-17-2015 08:05 PM
