X-link 2.1 (Reduced Engine Power) TPS Nitrous/Magnacharger
The TBSS throttle body dose not have stiff enough of a spring and will cause the the blade to flutter under boost and cause REP. Most boosted TBSS guys swapped in a LS2 TB which dose not flutter under boost.
This sounds more like an issue with the design of the WOT switch. Do you have any info on it and a wiring diagram for it?
You could also try tapping into the Accelerator Pedal Position sensor signal - use the dark blue wire at the 10 pin connector on the TAC module.
PS - Make sure that the pink wires inside both wire looms on the X-Link have not been cut if you are using the truck style 90mm TB.
Ok done some f*cking with wires. The truck doesnt go into "rep" mode when the nitrous is activated and it is stomped. The truck does go into "rep" mode when the nitrous is no activated and stomped. I think it is back feeding voltage some how. Can I put a diode in the WOT wire to stop this from happening? What size?
If you do try a small (1/4 watt) general purpose diode and it works, you will have to adjust your WOT settings afterward due to the voltage drop across the diode- typically .7V. Might also be that you need a resistor in there rather than a diode(e.g. 10Kohm-1/4 watt). Just guessing without knowing the schematics of the switch circuit. Did you contact the manufacturer of the switch?
I dont have a tester since I am back at school. Probably giong to buy one to check. I havent yet contacted the manufacturer (zex) but I did contact the installer of the nitrous and they did tell me that they have had similar problems and might need to install a diode. He was saying like 1 or 2 amp diode? I will reprogram the wot wire box after just to be safe. How would a resistor work it doesnt stop current like a diode does it?
Where do I find this wire? Diode installed and when the wot wire is attached and the nitrous is not activated still throw rep code. Any other suggestions.... "ride around with the nitrous always active" solution...ha
The TAC module is mounted on the driver's side firewall under the corner brace. There are 2 connectors plugged into the bottom of it, one 10 pin and one 16 pin. The APP sensor 1 signal is the dark blue wire on the 10 pin connector.
