XFI lobes for turbo cam?
Well it's time for a new setup. Gonna go all out on a 5.3 this time. My current mods are in my signature, everything will be the same except engine and cam. Scored a deal on an '04.5+ heavy rod 5.3. Getting head studs and gonna need anew cam. My stall is only a 3k, I've got 3.42 gears and a 77.6mm turbine with a 1.15 a/r housing. Basicly I'm gonna need a cam that spools quick and at low rpm but would like it to still pull at my 6500 shift points.
My current idea is to try a XFI 214/214 .600/.600 112 with 108 ICL. Any thoughts? What would you change?
I looked into the turbo cams martin@tick sells, my question is why so big? Does anyone have any proven et in a truck from these cams? Im sure they would shine on a dyno or a lightweight car but unless your spinning to 7k with a 4k stall and a brake I don't see them doing so well in a truck. Id like to hear some results from guys that have run them.
Gingervitis Addict
