XFI lobes for turbo cam?
Ill check it out. Foose's truck will be setup to pull up in that 7k rpm range and has the aid of the trans brake and 2 step so im sure its going to work real well in his truck, but maybe he will give some feed back on how it will do in street form.
Yeah thats just it, makes ppower were you need it. So what if its 20hp behind at 6400 rpn just add a lb of boost and you got 5 more hp and 50 more at 3500rpm. Just me thinking..
9 Second Truck Club
Thats not bad for a 4.8L with no brake! Prob only going to get mid low 1.5's anyway with a 2wd unless you are on a really good track. A trans brake is another advantage because it lets you run a tighter converter that would not work well on foot brake. I need to tighten my py 3400 up to a 3000 now that im not living in Colorado anymore. Think there it a tenth there.
