Got a questions about supercharging a 5.4
Did he buy everything for the conversion? If not he will also need upper and lower intake manifold, intercooler w/ resivour & pump, Heat exchanger, 42lb injectors, 90mm mass air meter, some sort of cold air intake set up, front engine braket that holds the blower belt tensioner and all pulleys for the blower belt, lower crank pulley. Im sure theres some things im forgeting.
i did some searching and found a list of stuff thats needed
Blower
manifold
intercooler
intercooler resivor
intercooler pump
throttle body arm
throttle body
front motor pulley bracket
all idler pulleys and tensioner
gator back blower belt
lightning alternator
lightning water pump
lightning throttle cable bracket
lightning throttle and cruise cables
lightning fan and shroud
Lightning heat exchanger
all hoses
42lb injectors
90mm mass air
Blower
manifold
intercooler
intercooler resivor
intercooler pump
throttle body arm
throttle body
all hoses
42lb injectors
90mm mass air
SWINGRRRR
09-03-2015 07:49 PM
