Ford Engine & Exhaust Performance All EFI, 4.6, 5.4 Triton
Ran with no oil after drain
Old 05-25-2010, 07:50 PM
wentbig's Avatar
Question Ran with no oil after drain
I just had one of the guys at work change my oil,5.4L F150 2006
I pulled out of the shop and got out leaving it run. After a min. It sounded like a diesel then stalled. It had no oil in it at all. After adding oil it would not turn over, I jumped it and kept bumping it. 5 mins later it started all is fine.
Do you think all the valves closed from the lifters going dry?
Old 05-25-2010, 09:47 PM
skeet's Avatar
appearantly he drained your oil!! not changed your oil lol!!
youre lucky if nothings messed up !!
Old 05-25-2010, 09:50 PM
Baltimore Whore
Mangled03gmc's Avatar
Maybe it is due to the cylinder walls drying up and stopping the engine. I think you might be screwed.. Prob scored the walls up..
Old 05-25-2010, 10:16 PM
Dewey's Avatar
i'm with john. i think the shop might be buying you a new engine.
Old 05-25-2010, 10:21 PM
03chevyroyce's Avatar
go get your new motor
Old 05-25-2010, 10:22 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
dayum! Oh man, I hope he wasn't doing you a favor!
Old 05-25-2010, 10:40 PM
TurboGibbs's Avatar
Wow. Sounds like an obvious mis-communication somewhere in the oil change process.
It depends, if this was a "fringe benefit" at work and having your oil changed, then your screwed. If it was a documented paid oil change, then you have a case.
If it was the first example, then throw a can of prolong in there and see what happens!
Old 05-25-2010, 10:50 PM
Wow...New motor time.
Old 05-25-2010, 11:30 PM
camochevy21's Avatar
Wow man, that sucks. Sorry to hear it.
Old 05-26-2010, 10:04 AM
SILVERADO11's Avatar
shity! hope there was a repair order wrote up for the oil change, other wise your **** outta luck! seen this same thing happen to a coworker of mine, he had a R.O. writen up and ended up getting a complet longblock installed for free.
Quick Reply: Ran with no oil after drain
