2011 Silverado need upgrade fuel pump
What kind of fuel pump upgrade can be done on a 2011 flex fuel pump module, if any? Have a DW340 to go in, just not sure what to do. Any help would be appreciated.
550+ rwhp is expected. It came to me running out of fuel and 95% injector duty cycle. Have 90lb injectors to go in and a DW340. Never done this mod on this module though. Need a little coaching. Thanks..
Process to delete FPCM with return fuel system
Unpluged the FPCM
*under the bed of the truck above the spare
Large Pins 47 & 16 with around 10 gauge wire supply ground and power to the pump
ground is Pink ...WT
Depin the connector and repin for new weather pack relay
Pin 13 Dark Green / white stripe is the trigger form the PCM key hot.
in HPT turn off P0230 and U0109
Then get what ever pump you want. Popular choice around here is walbro 400/450
Unpluged the FPCM
Unpluged the FPCM
Unpluged the FPCM
5.3lSilverado
25
08-29-2016 12:48 AM
InsaneDomestics
07-27-2015 02:42 PM
Mossyoakglock
07-17-2015 08:30 AM
