36lbs injectors good for a 408ci ?
have a L92 headed 408ci project ,didnt buy injectors yet because I want to upgrade to 80lbs later when going FI
will the 36lbs (flexfuel 6.0 injectors) be enough for the mean time
set up is :
408 ci
9.4:1 CR
230/236 @ .600/.600 @ 115LSA
stock truck intake/stock L92 heads/ stock borted TB
stock fuel pump and 36lb injectors
if I must go a tad up on injectors .. what should I get ? 42lbs ?
any one knows if the 2010 LS3 camaro injectors fit my intake ?
set up is :
408 ci
9.4:1 CR
You would be best off stepping up if you plan to make more power in the future I am hoping so with that low of compression. I think the new camaro injectors will fit I think they are side by side the same I have a set out of a flex fuel 5.3 truck on my desk and they are the same height as the 2010 camaro stockers
can I get 80lbs and run them with stock pump at low duty cycle ? , this will be temporary until I can buy a dual pumper setup witj bigger rails and lines
You can just set the rev limiter to wherever you start running out of injectors. That's what I did when I added my cam and pullied down, Wheatley just dropped my shift points to 5800 or something until I picked up my 75'ers.
But with the proper injector tuning yes no issue at all.
