After market fuel rails for stock intake
Does anybody make some aftermarket fuel rails for the NNBS intakes?
Edit: If anyone is curious, I was able to get some aftermarket fuel rails on my NNBS intake. I used the new Holley LS1/LS2/LS3 rails that have the different mounting holes on the bottom instead of the side holes. Due to the compound angle of the injectors, It wants to push the fuel rail into the pedestals on the intake thus not letting the injectors sit at the proper angle. What I ended up doing was end milling the pedestals down .200 and it ended up working out perfectly for me. The injectors now sit perfectly. Then, all I did was buy some flat piece of 1/8" steel to make my brackets and BAM, all done. Now to just decide on a fitting to clear the ALT....Oh by the way, I'm also using injector height adapters.
dr_whigham
02-14-2016 12:05 PM
dantheman1540
18
02-07-2016 10:04 PM
