Best Fuel Pump for LS Swap
Registered User
Thinking of putting stock Gen 4 5.3 in late 80s Blazer. I know I'm going to have to change out the fuel pump and likely add an external regulator.
I'm hoping to retain the stock tank, fuel sending unit, and fuel lines, though. Probably going to have to get creative with fuel line adapters with the stock saginaw ends.
Any suggestions for a fuel pump? Probably something from a mid 90s chevy pickup? Should require 50 to 60 psi, I think.
Registered User
Probably not much more than 350hp for now (mostly stock). The 255 would probably be fine. It's got a different plug so I'll have to solder if I use it. I've read that they are pretty loud and sometimes struggle to suck up fuel when tanks are half full. Thanks for the suggestion, though.
