Converting to return style with dual 255s?
Hey guys, boost is in the plans for winter changes. My Truck is an 05 with the return less fuel system. I currently have a walbro 255 pump in the stock bucket. To meet my fuel needs, I plan to run dual 255s and convert to return style with a boost referenced fpr under the hood. I plan to use the stock feed as a return since it is already ran and slightly bigger than -6. Plus the fittings are available to easily adapt -6 off the regulator to the stock line. I want to run -8 feed. So my question is this, what's the easiest way to get dual 255s out of the stock fuel bucket/hat with a -8 an feed? Also, what do I need to do in terms of wiring? Dual 10ga feeds and grounds from relay triggered by the stock pump wiring?
lxcoupe
10-04-2015 08:07 PM
GM1697
09-09-2015 01:52 PM
