Db rods cell tank
Db rods cell tank
I bought dB rods cell tank few months ago. I need a help and pictures would greatly. I use stock fuel sending. What about three ports do? I run all braid hoses with magnfuel pump. I run -12 sump line straight to regulator
just to make sure I understand correctly, you're running an external magnafuel pump, but used the OEM bucket just to utilize the stock sending unit?
the 3 ports should be a feed, return and vent. if you're running an external pump, just cap the feed and return, and loop a hose on the vent.
Of cell tank. I deleted evap stuff. Something need one of fuel port open for air? I need see anyone who done want picture so i can copy
It
Like stated cap off the return and feed ports.
Take and add a like to the vent. Loop it around 3 times and add a filter. This will allow fumes out but no fuel incase of rollover. This is how mine is done. Havnt had any issues.
Thank for rely back. I’m trying to understand what your saying. I’m trying see image what exact i need. Don’t you have pic or draw it.
Believe or not. I been google it. Before i comment here. There is lot of pictures i can’t find any good pictures info with three ports fuel sending. Because i run sump no more run factory and evap kit.
