Dual walbro 255 and dual Racetronix hotwire kit..
Old 01-11-2014 | 03:52 PM
  #21
BlackGMC's Avatar
Resident Retard
Originally Posted by 2toneblown
Did you have to redo the "Y" and fuel lines in the bucket from the pic in the OP? I know the bucket has to compress and that doesnt look like it will compress enough to fit. I am having thag problem with mine. I have too much of a bend in the hose and its splitting the lines once it gets too much pressure
Nope. When i assembled everything it was assembled at install height.
Old 01-11-2014 | 08:20 PM
  #22
lycominghunter's Avatar
I was looking at the a1000 and I just checked it again...all information that I can find is saying that its -6 inlet and -6 outlets
scratch that. Found an A1000 with -10 inlet, -10 outlet, and -6 return. Thanks for the help!!
Old 01-12-2014 | 05:58 PM
  #23
GMCtrk's Avatar
Just realized I dont need a Hobbs switch. I can activate a secondary fuel pump with my Eboost Street.
Old 01-12-2014 | 09:39 PM
  #24
Tootall's Avatar
did yall know that all of the trucks come with a 10g wire from the fuse box to the trailer hitch . . . . and it's not wired up to anything. So add a relay and a fuse and your fuel pump wire is already there and was never being used in the first place.
Old 01-12-2014 | 09:55 PM
  #25
GMCtrk's Avatar
Interesting. So does this wire have constant power at all times with the key on? Is this power wire fused up in the engine bay?
Old 01-12-2014 | 10:16 PM
  #26
Tootall's Avatar
Fused in as always hot. There's a solid red blank in the engine bay fuse box, add a fuse to it along with acrelay
Old 01-19-2014 | 11:57 AM
  #27
6.0l RST's Avatar
i wish i understood this stuff haha and i need to for my turbo set up
Old 01-19-2014 | 12:30 PM
  #28
timmay208's Avatar
Do you by chance have a PN for that fuel filter? And where did you find the 4psi hobb switch. This is exactly how im doing my setup great thread!!
Old 01-19-2014 | 12:48 PM
  #29
BlackGMC's Avatar
Resident Retard
Fuel filter
BILLET FUEL FLTR -8AN BLK
Hobbs switches
Racetronix - Hobbs
Old 01-19-2014 | 12:49 PM
  #30
timmay208's Avatar
Thanks a ton
Quick Reply: Dual walbro 255 and dual Racetronix hotwire kit..
