E85 Conversion?
E85 Conversion?
Ok guys as the title says I see people are switching to run E85 instead of running Meth. Im wanting to do the same thing since I'm buying all new fuel components to supplement my current build. I'm looking for tried and true setups from you truck vets out there. What works for you. Complete setups.
Heres the run down on my setup so far..
5.3 AFM delete TSP 220 112 LSA. PRC 2.5's KB racing Turbo kit with a 76 ON3 with 80lbs injectors...
So what's your guys suggestion to completely convert to E85 from pump to engine? I appreciate some insight.
Formerly ScreamingL
Have to be realistic with intentions of vehicle to give idea
Example my e85 fuel system is -12 feed -10 return 225lb injectors at 43 base belt drive pump
You wont need none of this unless you knew that yiu wanted 1500 rwhp range
