E85 Conversion?
Old 02-09-2016, 12:18 PM
!Hostile!'s Avatar
I have that kit as well im about to purchase the cold side and IC
Old 02-09-2016, 12:20 PM
!Hostile!'s Avatar
Ive got #80 INJ ive been thinking of buying George's 95's but Im thinking I wnt bigger yet to just buy once Im thinking 125's and be good till bigger powerplant.
Old 02-12-2016, 09:41 AM
kaze_v8's Avatar
If you've got high HP goals, then make the investment once and get the bigger injectors.
You lose nothing with having larger injectors.
Personally im running 82lb injectors, on a 340lph, and shooting for about 450-500whp on e85.
Old 02-14-2016, 12:22 AM
blue0453's Avatar
Dual 450 pumps, -8 feed stock feed as return, 115lbrs. Truck makes 750 with 90%dc.
Old 02-14-2016, 05:15 PM
!Hostile!'s Avatar
Help me out here what do you mean by 90% dc I'm not use to all these abbreviations
Old 02-14-2016, 05:26 PM
GMCtrk's Avatar
inejctor duty cycle
Old 02-14-2016, 06:45 PM
!Hostile!'s Avatar
Originally Posted by GMCtrk
inejctor duty cycle
That's what I assumed. How do you know that percentage or is it the way an injector is setup or tuned....I've been a BBC carb guy forever and never really seriously modded ls engines so I'm learning still.
Old 02-14-2016, 07:13 PM
blue0453's Avatar
When you log the truck make sure to log Idc and it will tell you
Old 02-14-2016, 09:04 PM
!Hostile!'s Avatar
So by logging your meaning when ur tuning? I appreciate this help I'm trying to square this away my Hp goal is 750-800. I'm trying to decide if I want to dabble in tuning I've had two mail order tunes and am not happy with it. Plus adding this turbo everybody says find someone that knows how to tune LS turbo vehicles. I asked for a quote from Speed iNC. for when I install turbo and fuel upgrades but got nothing back.
Old 02-14-2016, 10:47 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Tuning, is a process of modifying the parameters within the ECU usually to accommodate for new changes, I.e. larger cam, new heads, long tube headers, and so on. It's often done based on the data collected while logging.
Logging is taking data samples as you drive under different conditions to see if the changes you made are correct for your combination.
Tuning is done with an editor program while data logging is a scan tool program.
Both are separate programs used together when you buy a tuning suite from one of the few companies out there.
Hope that helps!
cfaluck13
10-16-2016 04:05 PM
WICK3DxGATA
05-02-2016 10:47 AM
376c5vette
12-29-2015 10:04 PM
WS6HUMMER
12-21-2015 12:54 PM
03chevytruck
12-20-2015 07:23 PM
Quick Reply: E85 Conversion?
