FAST fuel injectors vs bosch ?
Old 01-21-2013, 03:30 AM
sand man's Avatar
Default FAST fuel injectors vs bosch ?
I'm trying to get some fuel injectors that would support 800 flywheel HP on a 408ci L92 heads motor that will have a turbo later on
the injectors im looking at that will work with a stock gm fuel pump for now
sizes are FAST 65lbs or FIC 72lbs or 60lbs
all rated @ 43.5psi so with 58psi they'll flow more
the FAST runs at under 400$ and the FIC's for 600$
any one got some input on this ? ease of tuning, manners on Idel,quality and hp ratings
Old 01-21-2013, 06:23 AM
milkey57's Avatar
Go with the FIC's, they come with data, and that alone is worth it.
Old 01-21-2013, 07:20 AM
03sierraslt's Avatar
As mentioned, the data is the big thing. Just make sure whatever you get comes with all of the injector data.
Old 01-21-2013, 08:59 AM
sand man's Avatar
great , thanks
what about the stock fuel pump , can it handle the 60 or 72lbs @ 100% IDC or I'll have a pressure drop ?
Old 01-21-2013, 09:18 AM
What year is your truck? Is it flex fuel? Either way you are going to have pressure drop with a returnless system.
Old 01-21-2013, 03:30 PM
sand man's Avatar
09 non-flex fuel
Old 01-21-2013, 04:43 PM
sand man's Avatar
Chevrolet 2009 13 LS9 ZR1 72 lbs HR Set of 8 Direct Fit Fuel Injectors | eBay
do these look good ?
Old 01-21-2013, 06:58 PM
xx_ED_xx's Avatar
I got the fast 85 pounders in my truck think you can get them new for 380 for a set
supporting 750ish hp right now
Old 01-21-2013, 07:02 PM
lglowe's Avatar
I was told by fic that fast uses Bosch injectors anyway.
Old 01-21-2013, 07:04 PM
xx_ED_xx's Avatar
yes they are reman bosches still have bosch part numbers on them
Quick Reply: FAST fuel injectors vs bosch ?
